Aller au contenu principal
Sony NEX-7 Battery Replacement
  1. Sony NEX-7 Battery Replacement, Battery: étape 1, image 1 de 2 Sony NEX-7 Battery Replacement, Battery: étape 1, image 2 de 2
    • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
    • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
  2. Sony NEX-7 Battery Replacement: étape 2, image 1 de 1
    • Flip the camera over such that the power switch points down.
    • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
  3. Sony NEX-7 Battery Replacement: étape 3, image 1 de 1
    • With the battery door open, push the blue lever in the battery compartment to release the battery.
To replace the battery, fit it in the slot, then close and lock the door.
2 autres ont terminé cette réparation.
Tyler
Membre depuis le 04/22/14
569 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 10-55, Amido Spring 2014 Membre de l'équipe Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 membres
31 tutoriels rédigés
Un commentaire
I’ve done this about a million times. :)
Martin Hurley - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 2,036
