Aller au contenu principal
Introduction
This guide will show you how take out the SD card, which stores pictures and videos.
  1. We need to turn off the camera because we are removing components that could get damaged if the power is still on. If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
    • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
    • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
  2. Flip the camera over such that the power switch points down.
    • Flip the camera over such that the power switch points down.
    • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
  3. With the battery door open, push the blue lever in the battery compartment to release the battery.
    • With the battery door open, push the blue lever in the battery compartment to release the battery.
  4. To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
    • To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
    • Pull the card out with your fingers.
To replace the SD card, press the card into the slot until it clicks. It will stay on its own. If it doesn't go in all the way, make sure the gold contacts are down and towards the battery door.
2 autres ont terminé cette réparation.
Jay Miley
Membre depuis le 22/04/2014
4 658 Réputation
13 tutoriels rédigés
Équipe
Cal Poly, Team 10-55, Amido Spring 2014 Membre de l'équipe Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 membres
31 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 14
Total : 1,270
