Introduction
When completing this guide, do not damage the processor or motherboard.
Unscrew two 5 mm Phillips #00 screws using a Phillips #00 screwdriver located on the bottom of the back of the device.
  • Unscrew two 5 mm Phillips #00 screws using a Phillips #00 screwdriver located on the bottom of the back of the device.
Ajouter un commentaire
Using a plastic opening tool, loosen the bottom portion of device.
  • Using a plastic opening tool, loosen the bottom portion of device.
  • Using a plastic opening tool, loosen the top panel of the device.
  • Remove two 3 mm Philips #00 screws using a Phillips #00 screwdriver located on the portion under the top panel of the device.
  • Remove back plate from device.
  • Unscrew one 2.5 mm screw using a Phillips #00 screwdriver on bottom right portion of device located near audio jack.
  • Disconnect the headphone jack connection from the motherboard using any tool to remove black audio piece that needs to be replaced.
Chaz
Membre depuis le 16/01/2015
119 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 17-6, Watkins Winter 2015 Membre de l'équipe USF Tampa, Team 17-6, Watkins Winter 2015
USFT-WATKINS-W15S17G6
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 560
