Aller au contenu principal
Sony NWZ-E473 Audio Jack Replacement
Ce dont vous avez besoin
  1. Sony NWZ-E473 Audio Jack Replacement, Back Panel: étape 1, image 1 de 1
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
  2. Sony NWZ-E473 Audio Jack Replacement: étape 2, image 1 de 1
    • Use a plastic opening tool to loosen the bottom portion of device.
  3. Sony NWZ-E473 Audio Jack Replacement: étape 3, image 1 de 1
    • Use a plastic opening tool to loosen the top panel of the device.
  4. Sony NWZ-E473 Audio Jack Replacement: étape 4, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
  5. Sony NWZ-E473 Audio Jack Replacement: étape 5, image 1 de 3 Sony NWZ-E473 Audio Jack Replacement: étape 5, image 2 de 3 Sony NWZ-E473 Audio Jack Replacement: étape 5, image 3 de 3
    • Remove the back plate from the device.
  6. Sony NWZ-E473 Audio Jack Replacement, Audio Jack: étape 6, image 1 de 1
    • Unscrew one 2.5 mm screw using a Phillips #00 screwdriver on bottom right portion of device located near audio jack.
  7. Sony NWZ-E473 Audio Jack Replacement: étape 7, image 1 de 2 Sony NWZ-E473 Audio Jack Replacement: étape 7, image 2 de 2
    • Disconnect the headphone jack connection from the motherboard using any tool to remove black audio piece that needs to be replaced.
Chaz
Membre depuis le 01/16/15
119 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 17-6, Watkins Winter 2015 Membre de l'équipe USF Tampa, Team 17-6, Watkins Winter 2015
USFT-WATKINS-W15S17G6
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 1,064
