Aller au contenu principal
Sony NWZ-E473 Battery Replacement
Ce dont vous avez besoin
  1. Sony NWZ-E473 Battery Replacement, Back Panel: étape 1, image 1 de 1
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
  2. Sony NWZ-E473 Battery Replacement: étape 2, image 1 de 1
    • Use a plastic opening tool to loosen the bottom portion of device.
  3. Sony NWZ-E473 Battery Replacement: étape 3, image 1 de 1
    • Use a plastic opening tool to loosen the top panel of the device.
  4. Sony NWZ-E473 Battery Replacement: étape 4, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
  5. Sony NWZ-E473 Battery Replacement: étape 5, image 1 de 3 Sony NWZ-E473 Battery Replacement: étape 5, image 2 de 3 Sony NWZ-E473 Battery Replacement: étape 5, image 3 de 3
    • Remove the back plate from the device.
  6. Sony NWZ-E473 Battery Replacement, Battery: étape 6, image 1 de 2 Sony NWZ-E473 Battery Replacement, Battery: étape 6, image 2 de 2
    • Peel back the layer of tape along with the processor, which is located just below the battery, using the tweezers and the spudger.
  7. Sony NWZ-E473 Battery Replacement: étape 7, image 1 de 2 Sony NWZ-E473 Battery Replacement: étape 7, image 2 de 2
    • Slide a prying tool underneath the top portion of the battery and lift it from the case.
  8. Sony NWZ-E473 Battery Replacement: étape 8, image 1 de 1
    • Remove the stickers from the battery terminals, which are on the underside of the battery.
  9. Sony NWZ-E473 Battery Replacement: étape 9, image 1 de 1
    • Use a soldering iron to remove the wires from the red and the black terminals.
4 autres ont terminé cette réparation.
Matthew Hintz
Membre depuis le 01/16/15
327 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 17-6, Watkins Winter 2015 Membre de l'équipe USF Tampa, Team 17-6, Watkins Winter 2015
USFT-WATKINS-W15S17G6
4 membres
5 tutoriels rédigés
2 commentaires
Hi their I have a Sony nwz-e355 walkman I want to replace the battery in it cause I thinks it's done I see u do a replacement for the e473 wondering if u have e355 batteries or will this e473 battery work in my walkman both need to be soildered in any feed back would help
Derek Hebert - Réponse
I have the same model. I have 2 of them purchased years ago from Ubid.com. A very cool device. SONY ought to service them when the batteries fade…
guy lewit -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 36
Total : 9,501
