Aller au contenu principal
Sony NWZ-E473 Front Button Replacement
Ce dont vous avez besoin
  1. Sony NWZ-E473 Front Button Replacement, Back Panel: étape 1, image 1 de 1
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
  2. Sony NWZ-E473 Front Button Replacement: étape 2, image 1 de 1
    • Use a plastic opening tool to loosen the bottom portion of device.
  3. Sony NWZ-E473 Front Button Replacement: étape 3, image 1 de 1
    • Use a plastic opening tool to loosen the top panel of the device.
  4. Sony NWZ-E473 Front Button Replacement: étape 4, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
  5. Sony NWZ-E473 Front Button Replacement: étape 5, image 1 de 3 Sony NWZ-E473 Front Button Replacement: étape 5, image 2 de 3 Sony NWZ-E473 Front Button Replacement: étape 5, image 3 de 3
    • Remove the back plate from the device.
  6. Sony NWZ-E473 Front Button Replacement, Battery: étape 6, image 1 de 2 Sony NWZ-E473 Front Button Replacement, Battery: étape 6, image 2 de 2
    • Peel back the layer of tape along with the processor, which is located just below the battery, using the tweezers and the spudger.
  7. Sony NWZ-E473 Front Button Replacement: étape 7, image 1 de 2 Sony NWZ-E473 Front Button Replacement: étape 7, image 2 de 2
    • Slide a prying tool underneath the top portion of the battery and lift it from the case.
  8. Sony NWZ-E473 Front Button Replacement: étape 8, image 1 de 1
    • Remove the stickers from the battery terminals, which are on the underside of the battery.
  9. Sony NWZ-E473 Front Button Replacement: étape 9, image 1 de 1
    • Use a soldering iron to remove the wires from the red and the black terminals.
  10. Sony NWZ-E473 Front Button Replacement, Screen: étape 10, image 1 de 1
    • Use a nylon spudger or tweezers to remove the plastic USB cover.
  11. Sony NWZ-E473 Front Button Replacement: étape 11, image 1 de 1
    • Use a Phillips #00 screwdriver to unscrew two 2 mm screws located on the top corners of the device.
  12. Sony NWZ-E473 Front Button Replacement: étape 12, image 1 de 1
    • Use a nylon spudger or tweezers to remove the plastic protective plate at the top of device.
  13. Sony NWZ-E473 Front Button Replacement: étape 13, image 1 de 2 Sony NWZ-E473 Front Button Replacement: étape 13, image 2 de 2
    • Remove the plastic protective frame located over the motherboard with tweezers and a spudger.
  14. Sony NWZ-E473 Front Button Replacement: étape 14, image 1 de 1
    • Remove screen connection from motherboard using tweezers and spudger.
  15. Sony NWZ-E473 Front Button Replacement: étape 15, image 1 de 1
    • Use a Phillips #00 screwdriver to remove two 3 mm screws at the bottom sides and two 1 mm screws at top sides of the device.
  16. Sony NWZ-E473 Front Button Replacement: étape 16, image 1 de 2 Sony NWZ-E473 Front Button Replacement: étape 16, image 2 de 2
    • Use a Phillips #00 screwdriver to unscrew two 2 mm screws, and remove the motherboard from the device with tweezers and a plastic opening tool.
  17. Sony NWZ-E473 Front Button Replacement: étape 17, image 1 de 2 Sony NWZ-E473 Front Button Replacement: étape 17, image 2 de 2
    • Disconnect the metal shielding plate from the front panel with tweezers or a plastic opening tool.
  18. Sony NWZ-E473 Front Button Replacement: étape 18, image 1 de 2 Sony NWZ-E473 Front Button Replacement: étape 18, image 2 de 2
    • Use a plastic opening tool to remove the screen from metal back plate.
  19. Sony NWZ-E473 Front Button Replacement, Front Button: étape 19, image 1 de 1
    • Ensure that button connection is completely separated from the buttons.
  20. Sony NWZ-E473 Front Button Replacement: étape 20, image 1 de 3 Sony NWZ-E473 Front Button Replacement: étape 20, image 2 de 3 Sony NWZ-E473 Front Button Replacement: étape 20, image 3 de 3
    • Remove buttons from front display panel by pushing button display from the front of the device
Matthew Hintz
Membre depuis le 01/16/15
327 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 17-6, Watkins Winter 2015 Membre de l'équipe USF Tampa, Team 17-6, Watkins Winter 2015
USFT-WATKINS-W15S17G6
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,769
