Aller au contenu principal
Sony Pulse Elite Edition Battery Replacement
Ce dont vous avez besoin
  1. Sony Pulse Elite Edition Battery Replacement, Identifying Earpiece: étape 1, image 1 de 1
    • Locate the left side designation on the headband-earpiece junction.
    • The battery is in the right earpiece.
    • The motherboard is in the left earpiece.
  2. Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: étape 2, image 1 de 2 Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: étape 2, image 2 de 2
    • Gently pull around the perimeter of the left ear cushion until it comes off.
  3. Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: étape 3, image 1 de 2 Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: étape 3, image 2 de 2
    • Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup.
    • Gently pull the outer ear rim off of the headset assembly.
    • Harsh removal may cause permanent damage to the speaker wires.
  4. Sony Pulse Elite Edition Battery Replacement, Remove Speaker Housing: étape 4, image 1 de 1
    • Using tweezers, gently pry the red and black speaker wires from the attached socket.
  5. Sony Pulse Elite Edition Battery Replacement, Remove Battery: étape 5, image 1 de 2 Sony Pulse Elite Edition Battery Replacement, Remove Battery: étape 5, image 2 de 2
    • Lift up battery and disconnect wires using tweezers.
    • Use a new battery for reconstruction.
8 autres ont terminé cette réparation.
Chris Echter
Membre depuis le 01/29/15
862 Réputation
4 tutoriels rédigés
Équipe
Clemson, Team 14-2, Shirley Spring 2015 Membre de l'équipe Clemson, Team 14-2, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G2
5 membres
12 tutoriels rédigés
7 commentaires
Where can I buy the replacement battery for this?
Pretty hard to find...
francisklalumiere - Réponse
Replacement batteries can be found by googling "SP70C battery". It is a Lithium battery with 900mAh and a 3.7v output. AliExpress shows them for $11 including shipping.
David McAndrews - Réponse
Can I mod and replace the battery with a bigger one with no white connection, just positive and negative? Thanks!
marit - Réponse
Thank you so much for this guide. I got a 1000mAh batter from Amazon for 10 dollars. It lasts way longer and was extremely easy to install. Very thankful for this. Thanks!
sharku19z - Réponse
i just attempted... the connector to the battery just pulled off. NOTE: Pull up from PCB not out. The connector sets down into it.
Garrett Parmenter - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 58
Total : 10,211
