Aller au contenu principal
Sony Pulse Elite Edition Headband Replacement
Ce dont vous avez besoin
  1. Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: étape 1, image 1 de 2 Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: étape 1, image 2 de 2
    • Remove the two 5mm Phillips #00 screws from each side of the headband connected to the metal track.
  2. Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: étape 2, image 1 de 2 Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: étape 2, image 2 de 2
    • After removing the screws, push the small plastic protector on one of the sides towards the speaker closest to it.
    • After the protector has slid out of its slot, pull it away from the bar until it pops off the track.
    • Repeat this process for small plastic protector on the other side.
  3. Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: étape 3, image 1 de 3 Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: étape 3, image 2 de 3 Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: étape 3, image 3 de 3
    • Using your thumb, slide the cushion on one of the two adjusting rails toward the closest speaker.
    • Once enough of the cushion has separated from the rail, pull the rest of it off.
    • Repeat the process for the other rail.
  4. Sony Pulse Elite Edition Headband Replacement, Slide Headband Off Rails: étape 4, image 1 de 1
    • Gently pull the headband away from one of the speaker component groups, as if expanding it. Continue pulling until it is completely off the track.
    • Remove the white and red wires from inside the headband.
    • Be sure to keep the two speakers close together since they are still linked via the speaker wires.
    • Repeat this process for the other side.
3 autres ont terminé cette réparation.
Chris Echter
Membre depuis le 01/29/15
862 Réputation
4 tutoriels rédigés
Équipe
Clemson, Team 14-2, Shirley Spring 2015 Membre de l'équipe Clemson, Team 14-2, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G2
5 membres
12 tutoriels rédigés
Un commentaire
have any experience with the sony gold headset, i got two of them that broke in the same spot, right at the hinge
Rich Gallagher - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 41
Total : 5,497
