Aller au contenu principal
Sony RDR HX750 HX950 Disassembly
Ce dont vous avez besoin
  1. Sony RDR HX750 HX950 Disassembly, Remove cover: étape 1, image 1 de 3 Sony RDR HX750 HX950 Disassembly, Remove cover: étape 1, image 2 de 3 Sony RDR HX750 HX950 Disassembly, Remove cover: étape 1, image 3 de 3
    • Remove the screws from the back and sides of the top cover.
  2. Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: étape 2, image 1 de 3 Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: étape 2, image 2 de 3 Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: étape 2, image 3 de 3
    • Remove the four screws that secure the hard drive mounting bracket to the bottom of the unit.
    • Unplug the two cables from the rear of the hard drive.
    • Remove the four screws from the bottom of the hard drive mounting bracket.
  3. Sony RDR HX750 HX950 Disassembly, Remove DVD player: étape 3, image 1 de 3 Sony RDR HX750 HX950 Disassembly, Remove DVD player: étape 3, image 2 de 3 Sony RDR HX750 HX950 Disassembly, Remove DVD player: étape 3, image 3 de 3
    • Remove the screws from the DVD cover
    • Remove the screws from the plastic cable holder
  4. Sony RDR HX750 HX950 Disassembly, Remove front Panel: étape 4, image 1 de 3 Sony RDR HX750 HX950 Disassembly, Remove front Panel: étape 4, image 2 de 3 Sony RDR HX750 HX950 Disassembly, Remove front Panel: étape 4, image 3 de 3
    • Insert the paper under each "click" to remove the front panel.
    • Once each "click" is loose, push the front panel gently.
    • The table of the compact disk has a little plastic piece in front that goes up to come out with a "click"
  5. Sony RDR HX750 HX950 Disassembly, Remove  DVD block: étape 5, image 1 de 3 Sony RDR HX750 HX950 Disassembly, Remove  DVD block: étape 5, image 2 de 3 Sony RDR HX750 HX950 Disassembly, Remove  DVD block: étape 5, image 3 de 3
    • Unplug the cables show in photo.
    • Disconnect the cable hidden on the side.
    • Remove the piece on the cd reader
  6. Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: étape 6, image 1 de 3 Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: étape 6, image 2 de 3 Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: étape 6, image 3 de 3
    • Under the DVD block, remove the screws as shown.
    • Remove the screws on the board.
    • Now the laser can be accessed.
  7. Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: étape 7, image 1 de 3 Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: étape 7, image 2 de 3 Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: étape 7, image 3 de 3
    • Inserir instruções aqui.
To open this dvd recorder folow this tutorial
2 autres ont terminé cette réparation.
Cafony
Membre depuis le 02/17/15
687 Réputation
4 tutoriels rédigés
Un commentaire
Hello,HX950 work only with hdd 250Gb,or another,with 500 or 1000Gb ???
Cornelus - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 17
30 derniers jours : 58
Total : 5,427
