Aller au contenu principal
Sony RMT-D197A Battery Contactor Repair
Ce dont vous avez besoin
  1. Sony RMT-D197A Battery Contactor Repair, Sony RMT-D197A Battery Contactor Repair: étape 1, image 1 de 2 Sony RMT-D197A Battery Contactor Repair, Sony RMT-D197A Battery Contactor Repair: étape 1, image 2 de 2
    • Place the remote on a solid, sturdy surface.
    • Use a putty knife to gently pry open the remote.
  2. Sony RMT-D197A Battery Contactor Repair: étape 2, image 1 de 2 Sony RMT-D197A Battery Contactor Repair: étape 2, image 2 de 2
    • Remove the front panel from the remote.
  3. Sony RMT-D197A Battery Contactor Repair: étape 3, image 1 de 1
    • Wear safety glasses and use caution when handling a hot soldering iron.
    • Use the soldering iron to gently desolder the damaged battery contactor.
    • Keep in mind the battery contactor can easily break so make sure to be gentle with the soldering iron.
  4. Sony RMT-D197A Battery Contactor Repair: étape 4, image 1 de 2 Sony RMT-D197A Battery Contactor Repair: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use a pair of tweezers to remove the spring from the contactor.
  5. Sony RMT-D197A Battery Contactor Repair: étape 5, image 1 de 1
    • Use the soldering iron to melt solder onto the empty hole.
    • Make sure to accurately place the spring into the correct position.
  6. Sony RMT-D197A Battery Contactor Repair: étape 6, image 1 de 2 Sony RMT-D197A Battery Contactor Repair: étape 6, image 2 de 2
    • Reattach the two halves of the remote.
  7. Sony RMT-D197A Battery Contactor Repair: étape 7, image 1 de 1
    • Insert batteries and try out your remote.
Ligne d'arrivée
3 autres ont terminé cette réparation.
Ahmed Sultan
Membre depuis le 09/10/21
193 Réputation
1 tutoriel rédigé
Équipe
York University, Team 2-10, O'Regan Fall 2021 Membre de l'équipe York University, Team 2-10, O'Regan Fall 2021
YORK-O'REGAN-F21S2G10
1 membre
2 tutoriels rédigés
Un commentaire
As the remote is already disassembled, I took the opportunity to clean the contacts for all the buttons using alcohol.
Jason Lee - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 3
Total : 443
