Aller au contenu principal
Sony Reader Touch Edition PRS-600 Power Button Replacement
Ce dont vous avez besoin
  1. Sony Reader Touch Edition PRS-600 Power Button Replacement, Back Panel: étape 1, image 1 de 1
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
  2. Sony Reader Touch Edition PRS-600 Power Button Replacement: étape 2, image 1 de 1
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
  3. Sony Reader Touch Edition PRS-600 Power Button Replacement: étape 3, image 1 de 1
    • This is what the device should look like once the back cover panel has been removed.
  4. Sony Reader Touch Edition PRS-600 Power Button Replacement, Battery: étape 4, image 1 de 1
    • Once the back cover has been removed locate the battery in the bottom right corner of the device.
    • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
  5. Sony Reader Touch Edition PRS-600 Power Button Replacement: étape 5, image 1 de 1
    • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
  6. Sony Reader Touch Edition PRS-600 Power Button Replacement, Power Button: étape 6, image 1 de 1
    • Remove the stylus from the device.
  7. Sony Reader Touch Edition PRS-600 Power Button Replacement: étape 7, image 1 de 3 Sony Reader Touch Edition PRS-600 Power Button Replacement: étape 7, image 2 de 3 Sony Reader Touch Edition PRS-600 Power Button Replacement: étape 7, image 3 de 3
    • Using the Phillips screwdriver remove the 1.4 mm screw from the top panel.
    • Using the same screwdriver, remove the 1.4 mm screw from the back of the device.
    • Pry apart off the top panel of the device.
Zachary Jeffers
Membre depuis le 10/13/14
412 Réputation
4 tutoriels rédigés
Équipe
Clemson, Team 1-4, Benson Fall 2014 Membre de l'équipe Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 membres
22 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 7
Total : 553
