Ce dont vous avez besoin
Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
Once the back cover has been removed locate the battery in the bottom right corner of the device.
Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
Using a Phillips head screwdriver, remove the two 1.4 mm screws from the bottom panel of the device.
Using the same screwdriver, remove the 1.4 mm screw that is located on the back of the device.
Using a screwdriver remove the four 1.4 mm screws that are holding the black plastic casing in place.
Using a Phillips head screwdriver, remove the one 1.4 mm screw holding in the motherboard.
Using the flat end of the spudger, flip up the 4 latches holding down the thin, orange strips that connect the motherboard to the screen, audio/AC adapter/micro USB ports, and SD card/PRODuo ports.
To disconnect the the screen, audio/AC adapter/micro USB ports, and SD card/PRODuo ports pull each orange slip away from their corresponding latch.
Using a Phillips head screwdriver, remove the three 1.4 mm screws located on the SD/memory card holder.
Remove the SD/memory card holder from the device.
3 autres ont terminé cette réparation.
