Introduction
When replacing the flash unit from the camera, be sure to work on a flat surface. Since there are many wires and parts that come off, be sure to keep track of all the components within the flash unit. This requires using a Phillips #00 screwdriver and tweezers.
Ce dont vous avez besoin
Unscrew the four 4.0 mm Phillips #00 screws with a on the base of the camera below the the scheme that separates the front and back panels.
Unscrew the 5.0 mm Phillips #00 screw on the bottom right of the camera.
Unscrew the two 4.0 mm Phillips #00 screw at the top of the camera by the eyepiece.
Unscrew the 5.0 mm Phillips #00 screw of the dial below the other two screws.
Once all the screws are removed, carefully use your hands to detach the back panel from the camera. Working around the edges can help as well.
Remove the four 3.0 mm Phillips #00 screws.
Remove the 5.0 mm Phillips #00 screw.
Gently remove the 3.0 mm Phillips #00 screw on the back of the camera.
Remove the three 5.0 mm Phillips #00 screws on the front and left side of the camera.
Remove the five 3.0 mm Phillips #00 screws. It might take some force to start unscrewing these screws, but once they start to unscrew, they will become easy to take off.
Remove the three 5.0 mm Phillips #00 screws. These screws will need more force to get started. Unscrew the screws with the part against a surface.
4 autres ont terminé cette réparation.
2 commentaires
Pretty nice guide, except...
1. You forgot about the three screws above the flash assembly. You need to turn the camera on, and make the flash pop up first before disassembling, as there are three screws in total to remove that are hidden under the flash itself.
2. Also, a bit unnecessary removing all those motherboard connections as it just increases your chances of damaging the flex connections. You really only need to remove...
A. For the rear cover --> the two flexs for the rear cover for the LCD, and for the rear switches (which is exactly what the guide shows).
B. For the flash assy --> the blue flex, the two power cords (pink/white and dark grey/light grey), and the flex for mode dial (top left corner).
Guide was good, I use to repair camera's for a living (stopped a while ago), but I knew something was holding that top cover down, don't use the force people!
Hope this info helps others.
Cheers,
Chris
