Aller au contenu principal
Sony SRS-X7 Faceplate Disassembly
Ce dont vous avez besoin
  1. Sony SRS-X7 Faceplate Disassembly, Sony SRS-X7 Faceplate Disassembly: étape 1, image 1 de 2 Sony SRS-X7 Faceplate Disassembly, Sony SRS-X7 Faceplate Disassembly: étape 1, image 2 de 2
    • On the bottom of the device, you'll see 4 rubber pieces at the corners. Peel off these rubber pieces.
    • Unscrew the 4 10mm Philips J1 screws beneath them.
  2. Sony SRS-X7 Faceplate Disassembly: étape 2, image 1 de 3 Sony SRS-X7 Faceplate Disassembly: étape 2, image 2 de 3 Sony SRS-X7 Faceplate Disassembly: étape 2, image 3 de 3
    • The black stickers between the 4 foam pieces are there to protect the unit's warranty. If you try to send the device back to Sony after poking through said stickers, they will not accept it as the device has been tampered with.
    • Poke through said stickers and unscrew the 2 10mm Philips J1 screws beneath those.
    • Insert the blue plastic tool into the corner of the bottom faceplate and slide along the edge.
    • It will be a bit difficult as there is adhesive holding the faceplate to the unit, but with it bit of playing it should come off with ease.
  3. Sony SRS-X7 Faceplate Disassembly: étape 3, image 1 de 2 Sony SRS-X7 Faceplate Disassembly: étape 3, image 2 de 2
    • Using a metal spudger, insert it into one of the corners or sides of the units faceplate and lightly pry open.
    • While pried, insert a plastic opening tool and slide along the edges of the unit.
    • Repeat the last step on each side of the unit's faceplate, until the faceplate is off.
    • The first time you attempt to take the faceplate off of the speaker, it will be difficult because there is adhesive holding it to the unit. After this time, disassembly and reassembly should be easier.
  4. Sony SRS-X7 Faceplate Disassembly: étape 4, image 1 de 2 Sony SRS-X7 Faceplate Disassembly: étape 4, image 2 de 2
    • With the faceplate now off, the speakers should be revealed. There should be 8 visible screws around the border of the speakers. Remove the 8 10mm Philips J1 screws.
    • Take the 2 20mm Philips J1 screws out of the middle of the speaker as shown.
  5. Sony SRS-X7 Faceplate Disassembly: étape 5, image 1 de 2 Sony SRS-X7 Faceplate Disassembly: étape 5, image 2 de 2
    • The speaker should come out of the unit with ease, however you should use caution as it is still connected to the motherboard.
    • Take the whole speaker out, and disconnect the connectors from the motherboard by lightly pulling on them.
Ligne d'arrivée
Tyler Lamar
Membre depuis le 03/10/16
685 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-6, Catania Spring 2016 Membre de l'équipe UMass Dartmouth, Team 7-6, Catania Spring 2016
UMASSD-CATANIA-S16S7G6
3 membres
5 tutoriels rédigés
Un commentaire
can the battery be replaced?
Daniel Reverter - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 32
Total : 3,242
