Introduction
This guide will instruct you on how to replace the motherboard of the Sony SRS-XB40. The guide will start with disassembling the speaker, and then the the guide will explain how to replace the motherboard.
Ce dont vous avez besoin
Remove the speaker case from the outer casing by prying it from the base of the speaker using a metal spudger.
Remove the PH-1 (10mm) screw from the top of the speaker that is connected to the motherboard.
4 autres ont terminé cette réparation.
4 commentaires
This was a very informative breadown thanks. Im am looking to go further than this i am looking for the skhematic breadown of parts and resisters on the mother board. I have one that grounds out and wont come on so i just need to atlease be able to find the diodes on the board. Thanks again if ypu can help.
Indeed it is very informative, thanks for uploading these step details. I had to open up my same xb40 speaker coz it doesn’t start. When I pressed the power button the bluetooth light blinks for 2-3 sec and then it goes off along with the power light. So I showed the motherboard to the bluetooth speaker repair man, he told me the problem is with bluetooth chip without checking the circuit board. Can you further guide me on this please, where should i find the new motherboard, I live in India.
Where can I get a motherboard for the SRS-XB40?
Did you have any luck sourcing one?
maxhodg -
