Aller au contenu principal
Sony SRS-XE200 Charging Port Replacement
Ce dont vous avez besoin
  1. Sony SRS-XE200 Charging Port Replacement, Speaker Assembly: étape 1, image 1 de 2 Sony SRS-XE200 Charging Port Replacement, Speaker Assembly: étape 1, image 2 de 2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Charging Port Replacement: étape 2, image 1 de 1
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Charging Port Replacement: étape 3, image 1 de 2 Sony SRS-XE200 Charging Port Replacement: étape 3, image 2 de 2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Charging Port Replacement: étape 4, image 1 de 2 Sony SRS-XE200 Charging Port Replacement: étape 4, image 2 de 2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Charging Port Replacement, Battery: étape 5, image 1 de 3 Sony SRS-XE200 Charging Port Replacement, Battery: étape 5, image 2 de 3 Sony SRS-XE200 Charging Port Replacement, Battery: étape 5, image 3 de 3
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Charging Port Replacement: étape 6, image 1 de 3 Sony SRS-XE200 Charging Port Replacement: étape 6, image 2 de 3 Sony SRS-XE200 Charging Port Replacement: étape 6, image 3 de 3
    • Remove the battery from the battery holder with a nylon spudger.
    • Unplug the battery from the motherboard.
  7. Sony SRS-XE200 Charging Port Replacement, Charging Port: étape 7, image 1 de 2 Sony SRS-XE200 Charging Port Replacement, Charging Port: étape 7, image 2 de 2
    • Remove the charging port.
Vishant Savaliya
Membre depuis le 02/09/23
361 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 12
30 derniers jours : 21
Total : 363
