Aller au contenu principal
Sony SRS-XE200 Microphone Replacement
Ce dont vous avez besoin
  1. Sony SRS-XE200 Microphone Replacement, Speaker Assembly: étape 1, image 1 de 2 Sony SRS-XE200 Microphone Replacement, Speaker Assembly: étape 1, image 2 de 2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Microphone Replacement: étape 2, image 1 de 1
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Microphone Replacement: étape 3, image 1 de 2 Sony SRS-XE200 Microphone Replacement: étape 3, image 2 de 2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Microphone Replacement: étape 4, image 1 de 2 Sony SRS-XE200 Microphone Replacement: étape 4, image 2 de 2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Microphone Replacement, Battery: étape 5, image 1 de 3 Sony SRS-XE200 Microphone Replacement, Battery: étape 5, image 2 de 3 Sony SRS-XE200 Microphone Replacement, Battery: étape 5, image 3 de 3
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Microphone Replacement: étape 6, image 1 de 3 Sony SRS-XE200 Microphone Replacement: étape 6, image 2 de 3 Sony SRS-XE200 Microphone Replacement: étape 6, image 3 de 3
    • Remove the battery from the battery holder with a nylon spudger.
    • Unplug the battery from the motherboard.
  7. Sony SRS-XE200 Microphone Replacement, Charging Port: étape 7, image 1 de 2 Sony SRS-XE200 Microphone Replacement, Charging Port: étape 7, image 2 de 2
    • Remove the charging port.
  8. Sony SRS-XE200 Microphone Replacement, Microphone: étape 8, image 1 de 3 Sony SRS-XE200 Microphone Replacement, Microphone: étape 8, image 2 de 3 Sony SRS-XE200 Microphone Replacement, Microphone: étape 8, image 3 de 3
    • Remove the two 0.8 mm screws connecting the motherboard to the microphone with a Phillips #1 screwdriver.
    • Remove the microphone.
  9. Sony SRS-XE200 Microphone Replacement: étape 9, image 1 de 1
  10. Sony SRS-XE200 Microphone Replacement: étape 10, image 1 de 2 Sony SRS-XE200 Microphone Replacement: étape 10, image 2 de 2
  11. Sony SRS-XE200 Microphone Replacement: étape 11, image 1 de 3 Sony SRS-XE200 Microphone Replacement: étape 11, image 2 de 3 Sony SRS-XE200 Microphone Replacement: étape 11, image 3 de 3
    • Remove the microphone from the case of the speaker.
    • Replace the microphone.
Vishant Savaliya
Membre depuis le 02/09/23
361 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 6
Total : 197
