Aller au contenu principal
Sony SS-CCP1 Speaker Replacement
Ce dont vous avez besoin
  1. Sony SS-CCP1 Speaker Replacement, Screen: étape 1, image 1 de 3 Sony SS-CCP1 Speaker Replacement, Screen: étape 1, image 2 de 3 Sony SS-CCP1 Speaker Replacement, Screen: étape 1, image 3 de 3
    • Pull screen cover from the edges for removal. This will not require much effort.
  2. Sony SS-CCP1 Speaker Replacement, Speaker: étape 2, image 1 de 2 Sony SS-CCP1 Speaker Replacement, Speaker: étape 2, image 2 de 2
    • Remove the seven 18.06mm PH1 screws.
  3. Sony SS-CCP1 Speaker Replacement: étape 3, image 1 de 3 Sony SS-CCP1 Speaker Replacement: étape 3, image 2 de 3 Sony SS-CCP1 Speaker Replacement: étape 3, image 3 de 3
    • Remove the crimps from the tweeter speaker.
    • If its not connected too tightly the crimps can be removed by hand pressure only.
    • If its too tight to be removed by hand, then you can use a pair of pliers to removed the crimps.
    • Never remove by pulling on the cables. Always pull by the metal crimps.
  4. Sony SS-CCP1 Speaker Replacement: étape 4, image 1 de 3 Sony SS-CCP1 Speaker Replacement: étape 4, image 2 de 3 Sony SS-CCP1 Speaker Replacement: étape 4, image 3 de 3
    • Remove the crimps from the 12cm loudspeaker.
  5. Sony SS-CCP1 Speaker Replacement: étape 5, image 1 de 2 Sony SS-CCP1 Speaker Replacement: étape 5, image 2 de 2
    • Remove the grommet using an object with a flat edge.
    • The grommet is not made of rubber, it is made of plastic. Be careful when removing it, as it can break easily.
  6. Sony SS-CCP1 Speaker Replacement: étape 6, image 1 de 2 Sony SS-CCP1 Speaker Replacement: étape 6, image 2 de 2
    • Feed the speaker cable through the front of the box.
4 autres ont terminé cette réparation.
Dallas
Membre depuis le 10/10/16
892 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 3-2, Baechle Fall 2016 Membre de l'équipe IUPUI, Team 3-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G2
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 33
Total : 3,914
