Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
This guide will aid readers to replace BIOS Battery of the device when the BIOS Battery dead.
  1. Follow Sony VAIO PCG-3E2L Battery Replacement to the device to remove the battery
  2. Using a #00 Phillips screwdriver, remove the screws Using a #00 Phillips screwdriver, remove the screws
    • Using a #00 Phillips screwdriver, remove the screws
  3. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  4. Lift the back cover panel. DO NOT force open the back panel.
    • Lift the back cover panel.
    • DO NOT force open the back panel.
    • The back cover panel should be lift up easily. If you feel there is resistance, please check if you have all screws removed.
  5. Use the Plastic Opening Tools to help pop  the BIOS Battery. Use the Plastic Opening Tools to help pop  the BIOS Battery. Use the Plastic Opening Tools to help pop  the BIOS Battery.
    • Use the Plastic Opening Tools to help pop the BIOS Battery.
3 autre(s) ont terminé cette réparation.
Chengyang Chen
Membre depuis le 27/03/2015
858 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-2, Kish Spring 2015 Membre de l'équipe UMass Dartmouth, Team 5-2, Kish Spring 2015
UMASSD-KISH-S15S5G2
4 membres
5 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 9
7 derniers jours : 41
30 derniers jours : 188
Total : 4,699
