Aller au contenu principal
Sony VAIO PCG-933A Floppy Disk Drive Replacement
  1. Sony VAIO PCG-933A Floppy Disk Drive Replacement, Battery: étape 1, image 1 de 2 Sony VAIO PCG-933A Floppy Disk Drive Replacement, Battery: étape 1, image 2 de 2
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A Floppy Disk Drive Replacement: étape 2, image 1 de 3 Sony VAIO PCG-933A Floppy Disk Drive Replacement: étape 2, image 2 de 3 Sony VAIO PCG-933A Floppy Disk Drive Replacement: étape 2, image 3 de 3
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. Sony VAIO PCG-933A Floppy Disk Drive Replacement, Floppy Disk Drive: étape 3, image 1 de 1
    • With the laptop facing you, turn the laptop upside down.
  4. Sony VAIO PCG-933A Floppy Disk Drive Replacement: étape 4, image 1 de 3 Sony VAIO PCG-933A Floppy Disk Drive Replacement: étape 4, image 2 de 3 Sony VAIO PCG-933A Floppy Disk Drive Replacement: étape 4, image 3 de 3
    • Locate the release switch in the center of the laptop, shown here.
    • Slide the switch, and hold in place. The floppy disk drive is now free and should easily slide out.
  5. Sony VAIO PCG-933A Floppy Disk Drive Replacement: étape 5, image 1 de 1
    • To replace, insert the new floppy disk drive with the wording facing down.
Sara Lillard
Membre depuis le 04/11/11
165 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 12-36, Maness Spring 2011 Membre de l'équipe Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,992
