Introduction
This guide will inform readers on how to safely uninstall the display of the Sony VAIO VPC-EB33FM laptop.
Outils
Pièces
If the laptop isn't turned off, then do so by holding down the power button.
Turn the laptop onto its backside.
Remove all charge from the laptop by holding down the power button for at least 5 seconds.
Using a Phillips #00 screwdriver remove the following screws securing the back cover :
Two 3.8-mm screws
Two 8.9-mm screws
Twelve 7.75-mm screws
Use a Phillips #1 screwdriver to remove the three 8.88-mm screws attached to the metal hinge at the corner of the laptop.
Repeat for the three screws on the opposite corner.
Use the plastic opening tool to separate the plastic front cover by wedging the tool along the seam.
Flip the laptop to the other side. If the front cover is still attached continue using the plastic opening tool to separate.
Carefully lift up the display. Completely detach the front plastic cover.
Annulation : je n'ai pas terminé ce guide.
2 autre(s) ont terminé cette réparation.
