Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This guide will inform readers on how to safely uninstall the hard drive of the Sony VAIO VPC-EB33FM laptop using your hands and a Phillips #00 screwdriver.
  1. If the laptop isn't turned off, then do so by holding down the power button. Turn the laptop onto its backside.
    • If the laptop isn't turned off, then do so by holding down the power button.
    • Turn the laptop onto its backside.
  2. Locate the battery below the screen attachment.
    • Locate the battery below the screen attachment.
    • The battery is shaped as a long rectangle with rounded edges.
  3. Press into the release button while holding the unlock button in position.
    • Press into the release button while holding the unlock button in position.
  4. Lift the battery out at the notch while holding the release button. Lift the battery out at the notch while holding the release button.
    • Lift the battery out at the notch while holding the release button.
  5. Le kit d'outils Essentiel
    Les outils les plus utiles dans notre kit le plus compact.
    J'achète
    J'achète
  6. Remove all charge from the laptop by holding down the power button for at least 5 seconds.
    • Remove all charge from the laptop by holding down the power button for at least 5 seconds.
  7. Turn laptop onto its backside and locate the hard drive cover panel. Turn laptop onto its backside and locate the hard drive cover panel.
    • Turn laptop onto its backside and locate the hard drive cover panel.
  8. Use a Phillips #00 screwdriver to remove the two 7.75-mm cover screws on the bottom corners of the panel. Use a Phillips #00 screwdriver to remove the two 7.75-mm cover screws on the bottom corners of the panel. Use a Phillips #00 screwdriver to remove the two 7.75-mm cover screws on the bottom corners of the panel.
    • Use a Phillips #00 screwdriver to remove the two 7.75-mm cover screws on the bottom corners of the panel.
  9. Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off. You may need to use your other hand to safely remove the panel. You can also use a spudger for this step
    • Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
    • You may need to use your other hand to safely remove the panel.
    • You can also use a spudger for this step
  10. The hard drive should now be exposed.
    • The hard drive should now be exposed.
    • Remove the two remaining 7.75-mm screws using the Phillips #00 screwdriver.
  11. Grab the tab between your thumb and index finger.
    • Grab the tab between your thumb and index finger.
    • Hold the hard drive securely in a horizontal position using your other hand.
    • Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
    • To prevent damage of the connection on the hard disk drive or the laptop, perform this task slowly and with care.
  12. While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle. Pull the hard drive out.
    • While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle.
    • Pull the hard drive out.
  13. If you need to remove the bracket from the hard drive, follow the next few steps: Remove the two 3.67-mm screws from either side of the bracket with a Phillips #00 screwdriver.
    • If you need to remove the bracket from the hard drive, follow the next few steps:
    • Remove the two 3.67-mm screws from either side of the bracket with a Phillips #00 screwdriver.
    • Lift the bracket off the hard drive.
7 autre(s) ont terminé cette réparation.
Christian
Membre depuis le 14/01/2013
142 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 18-39, Regan Winter 2013 Membre de l'équipe Cal Poly, Team 18-39, Regan Winter 2013
CPSU-REGAN-W13S18G39
5 membres
6 tutoriels rédigés
This is very good step by step instructions guide. Loved it and was able to remove my laptop hd very easily. I created this account only to say thanks to writer. Amazing job !! Thaks ton.
Dinesh - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 15
Total : 17,752
