Aller au contenu principal
Sony Vaio Fit SVF13N1ASNS Display Replacement
Ce dont vous avez besoin
  1. Sony Vaio Fit SVF13N1ASNS Display Replacement, Battery: étape 1, image 1 de 2 Sony Vaio Fit SVF13N1ASNS Display Replacement, Battery: étape 1, image 2 de 2
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Sony Vaio Fit SVF13N1ASNS Display Replacement: étape 2, image 1 de 2 Sony Vaio Fit SVF13N1ASNS Display Replacement: étape 2, image 2 de 2
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Sony Vaio Fit SVF13N1ASNS Display Replacement: étape 3, image 1 de 3 Sony Vaio Fit SVF13N1ASNS Display Replacement: étape 3, image 2 de 3 Sony Vaio Fit SVF13N1ASNS Display Replacement: étape 3, image 3 de 3
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Sony Vaio Fit SVF13N1ASNS Display Replacement: étape 4, image 1 de 1
    • Lift the battery up and pull it out of the laptop.
  5. Sony Vaio Fit SVF13N1ASNS Display Replacement, Display: étape 5, image 1 de 1
    • Open the laptop and rotate the screen to the back side.
    • Remove the eight 2.85mm Phillips #00 screws from the back of the screen.
  6. Sony Vaio Fit SVF13N1ASNS Display Replacement: étape 6, image 1 de 2 Sony Vaio Fit SVF13N1ASNS Display Replacement: étape 6, image 2 de 2
    • Rotate the screen back and close the laptop.
    • Use a plastic opening tool to carefully pry up the back plastic case.
    • Remove the back plastic case by sliding it down and pulling upwards.
  7. Sony Vaio Fit SVF13N1ASNS Display Replacement: étape 7, image 1 de 2 Sony Vaio Fit SVF13N1ASNS Display Replacement: étape 7, image 2 de 2
    • Remove the thirteen 2.85mm Phillips #00 screws from the screen.
  8. Sony Vaio Fit SVF13N1ASNS Display Replacement: étape 8, image 1 de 3 Sony Vaio Fit SVF13N1ASNS Display Replacement: étape 8, image 2 de 3 Sony Vaio Fit SVF13N1ASNS Display Replacement: étape 8, image 3 de 3
    • Use a spudger to lift up the black latch on the ZIF connector.
    • Pull the display ribbon cable out of the ZIF connector.
  9. Sony Vaio Fit SVF13N1ASNS Display Replacement: étape 9, image 1 de 3 Sony Vaio Fit SVF13N1ASNS Display Replacement: étape 9, image 2 de 3 Sony Vaio Fit SVF13N1ASNS Display Replacement: étape 9, image 3 de 3
    • Remove the display cable peeling up the tape.
    • The display cable locking mechanism is attached to the tape.
  10. Sony Vaio Fit SVF13N1ASNS Display Replacement: étape 10, image 1 de 1
    • Remove the display.
3 autres ont terminé cette réparation.
Althea McDavid
Membre depuis le 02/14/18
857 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S2-G4, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S2-G4, Nance Spring 2018
USFT-NANCE-S18S2G4
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 2,492
