Aller au contenu principal
Sony Vaio PCG-161L Hard Drive Replacement
Ce dont vous avez besoin
  1. Sony Vaio PCG-161L Hard Drive Replacement, Keyboard: étape 1, image 1 de 1
    • Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
  2. Sony Vaio PCG-161L Hard Drive Replacement: étape 2, image 1 de 2 Sony Vaio PCG-161L Hard Drive Replacement: étape 2, image 2 de 2
    • Lift up underneath the keyboard using the iFixit opening tool to expose the ribbon wires connecting the keyboard to the motherboard.
  3. Sony Vaio PCG-161L Hard Drive Replacement: étape 3, image 1 de 2 Sony Vaio PCG-161L Hard Drive Replacement: étape 3, image 2 de 2
    • The two ribbon cables connecting the keyboard to the motherboard are held in using zero insertion force (ZIF) connectors.
    • Use a plastic opening tool or your fingernail to flip up the small retaining flaps, then pull the ribbon cables out of their connectors.
  4. Sony Vaio PCG-161L Hard Drive Replacement, Hard Drive: étape 4, image 1 de 1
    • Remove the three 10 mm screws holding the casing to the top of the motherboard using a Phillips screwdriver.
  5. Sony Vaio PCG-161L Hard Drive Replacement: étape 5, image 1 de 1
    • Remove the 6 mm screw on the left side of the battery that holds the casing to the device using a phillips head screwdriver.
  6. Sony Vaio PCG-161L Hard Drive Replacement: étape 6, image 1 de 1
    • Turn the device upside down and remove the other 6 mm screw holding the casing to the device using a phillips head screwdriver.
  7. Sony Vaio PCG-161L Hard Drive Replacement: étape 7, image 1 de 2 Sony Vaio PCG-161L Hard Drive Replacement: étape 7, image 2 de 2
    • Remove the top casing by lifting up on the plastic.
    • There are no longer any wires connecting the casing to the motherboard. The casing can be fully removed and put to the side.
  8. Sony Vaio PCG-161L Hard Drive Replacement: étape 8, image 1 de 1
    • The ribbon cable covering the hard drive and connecting to the motherboard is held in using zero insertion force (ZIF) connector.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps, then pull the ribbon cable out.
  9. Sony Vaio PCG-161L Hard Drive Replacement: étape 9, image 1 de 1
    • Remove the four 5 mm screws holding the hard drive to the motherboard.
  10. Sony Vaio PCG-161L Hard Drive Replacement: étape 10, image 1 de 1
    • Remove the ribbon cable connecting the motherboard to the hard drive by pulling the female connector off of the pins attached the hard drive.
Roman Alshehri
Membre depuis le 03/08/17
407 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G2, Botvin Spring 2017 Membre de l'équipe UMass Dartmouth, Team S3-G2, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G2
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 17
Total : 969
