Introduction
If your laptop isn’t charging, or its overheating you may need to replace the motherboard. This guide will show you how to remove and replace the motherboard. The tools required are: an iFixit opening tool, a PH0 cross tip screwdriver, and needle nose pliers.
Ce dont vous avez besoin
Using a #0PH screwdriver, unscrew the three 4.80mm screws on the back of the device.
The screws are held into the panel by washers, they will not fall out once unscrewed.
Remove all nine 5.63mm screws with the #0PH screwdriver.
Remove the four 8.62mm screws with the #0PH screwdriver.
Remove the three 5.63mm screws using the 0PH screwdriver.
Remove the motherboard.
