Aller au contenu principal
Sony Vaio PCG-61411L Optical Disc Drive Replacement
Ce dont vous avez besoin
  1. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Battery: étape 1, image 1 de 3 Sony Vaio PCG-61411L Optical Disc Drive Replacement, Battery: étape 1, image 2 de 3 Sony Vaio PCG-61411L Optical Disc Drive Replacement, Battery: étape 1, image 3 de 3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio PCG-61411L Optical Disc Drive Replacement: étape 2, image 1 de 3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: étape 2, image 2 de 3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: étape 2, image 3 de 3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Hard Drive: étape 3, image 1 de 1
    • The hard drive panel is located in the bottom right corner of the device.
  4. Sony Vaio PCG-61411L Optical Disc Drive Replacement: étape 4, image 1 de 2 Sony Vaio PCG-61411L Optical Disc Drive Replacement: étape 4, image 2 de 2
    • Using the PH #0 screwdriver, unscrew the two 6.5mm screws located in the bottom left and middle right of the panel. The screws remain in the panels.
    • Remove the panel by pulling it up towards yourself.
  5. Sony Vaio PCG-61411L Optical Disc Drive Replacement: étape 5, image 1 de 3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: étape 5, image 2 de 3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: étape 5, image 3 de 3
    • Using a PH0 screwdriver, remove the four 3mm silver screws located in the external hard drive cover.
    • Using a PH00 screwdriver, remove the final 3mm black screw located in the top right section of the hard drive cover.
    • Carefully remove the silver hard drive cover.
  6. Sony Vaio PCG-61411L Optical Disc Drive Replacement: étape 6, image 1 de 3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: étape 6, image 2 de 3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: étape 6, image 3 de 3
    • Detach the hard drive by disconnecting it from the motherboard, pulling it gently from left to right.
  7. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Optical Disc Drive: étape 7, image 1 de 2 Sony Vaio PCG-61411L Optical Disc Drive Replacement, Optical Disc Drive: étape 7, image 2 de 2
    • Remove the 5mm screws with the PH0 screwdriver.
    • Remove the 3mm screws with the PH0 screwdriver.
  8. Sony Vaio PCG-61411L Optical Disc Drive Replacement: étape 8, image 1 de 2 Sony Vaio PCG-61411L Optical Disc Drive Replacement: étape 8, image 2 de 2
    • Lift the backplate from bottom right and left corner and remove it from the laptop.
  9. Sony Vaio PCG-61411L Optical Disc Drive Replacement: étape 9, image 1 de 2 Sony Vaio PCG-61411L Optical Disc Drive Replacement: étape 9, image 2 de 2
    • Slide your finger from the right of the optical disc and pull the optical disc from right to left.
Patrick Jean Baptiste
Membre depuis le 03/01/18
214 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G1, Simcock Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G1, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 10
Total : 617
