Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
This step-by-step guide will lead you through the process of removing the back panel of a Sony Vaio PCG-61A14L Laptop. The back panel would need to be replaced if cracked or broken. Removing the back panel requires very little force should be needed to remove the back panel. If difficult to remove, ensure that all the screws have been removed.
  1. Flip the laptop so the bottom is facing up with the model number visible.
    • Flip the laptop so the bottom is facing up with the model number visible.
  2. Slide the lock switch down until you hear a click to unlock the battery. Slide the lock switch down until you hear a click to unlock the battery.
    • Slide the lock switch down until you hear a click to unlock the battery.
  3. Slide the release slider up and simultaneously push the battery upwards away from the device until it falls out of place. Slide the release slider up and simultaneously push the battery upwards away from the device until it falls out of place.
    • Slide the release slider up and simultaneously push the battery upwards away from the device until it falls out of place.
  4. Remove the battery from the battery compartment. Remove the battery from the battery compartment.
    • Remove the battery from the battery compartment.
  5. Loosen the two (7mm) screws that hold the hard drive panel in place with a JIS #0 screwdriver.
    • Loosen the two (7mm) screws that hold the hard drive panel in place with a JIS #0 screwdriver.
    • These screws cannot be removed.
  6. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  7. Remove the plastic and unscrew the screw on the hard drive using the JIS #0 screwdriver.
    • Remove the plastic and unscrew the screw on the hard drive using the JIS #0 screwdriver.
  8. Push the hard drive towards the optical reader to unlock it.
    • Push the hard drive towards the optical reader to unlock it.
  9. Remove the hard drive from the device.
    • Remove the hard drive from the device.
  10. After you remove the battery, there is a small rectangular panel underneath where the battery was housed.
    • After you remove the battery, there is a small rectangular panel underneath where the battery was housed.
  11. Remove the single screw holding the panel in place using the JIS #0 screwdriver.
    • Remove the single screw holding the panel in place using the JIS #0 screwdriver.
  12. Remove the green circuit board  by dislodging the circuit it is attached to. Unhook it and remove it from the device. Unhook it and remove it from the device.
    • Remove the green circuit board by dislodging the circuit it is attached to.
    • Unhook it and remove it from the device.
  13. Remove the remaining eleven 7mm screws from back panel using the JIS #0 screwdriver.
    • Remove the remaining eleven 7mm screws from back panel using the JIS #0 screwdriver.
  14. Remove the back panel from the device. Remove the back panel from the device.
    • Remove the back panel from the device.
Sara Alfaro
Membre depuis le 08/03/2019
531 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G4, Botvin Spring 2019 Membre de l'équipe UMass Dartmouth, Team S1-G4, Botvin Spring 2019
UMASSD-BOTVIN-S19S1G4
4 membres
5 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 18
Total : 241
