Aller au contenu principal
Sony Vaio VPCEB11FM Hard Drive Replacement
Ce dont vous avez besoin
  1. Sony Vaio VPCEB11FM Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM Hard Drive Replacement: étape 2, image 1 de 1
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM Hard Drive Replacement: étape 3, image 1 de 1
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM Hard Drive Replacement, Hard Drive: étape 4, image 1 de 2 Sony Vaio VPCEB11FM Hard Drive Replacement, Hard Drive: étape 4, image 2 de 2
    • Using the Phillips #01 Screwdriver, remove the two 7mm screws.
  5. Sony Vaio VPCEB11FM Hard Drive Replacement: étape 5, image 1 de 3 Sony Vaio VPCEB11FM Hard Drive Replacement: étape 5, image 2 de 3 Sony Vaio VPCEB11FM Hard Drive Replacement: étape 5, image 3 de 3
    • Use your fingers to pry the cover upward.
    • Unscrew the two 7mm screws.
    • Pull the plastic tab in the direction of the arrow to take out.
  6. Sony Vaio VPCEB11FM Hard Drive Replacement: étape 6, image 1 de 2 Sony Vaio VPCEB11FM Hard Drive Replacement: étape 6, image 2 de 2
    • Lift plug side first.
    • Remove all the way.
  7. Sony Vaio VPCEB11FM Hard Drive Replacement: étape 7, image 1 de 3 Sony Vaio VPCEB11FM Hard Drive Replacement: étape 7, image 2 de 3 Sony Vaio VPCEB11FM Hard Drive Replacement: étape 7, image 3 de 3
    • Skip to next step if accessing other components.
    • Remove the 3mm screws with the Phillips #1 Screwdriver from hard drive bracket.
2 autres ont terminé cette réparation.
Maxine Filcher
Membre depuis le 01/30/17
1 102 Réputation
8 tutoriels rédigés
Équipe
UW Tacoma, Team 1-5, Rose Winter 2017 Membre de l'équipe UW Tacoma, Team 1-5, Rose Winter 2017
UWT-ROSE-W17S1G5
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 39
Total : 3,946
