Aller au contenu principal
Introduction
This guide helps users replace the RAM in the Sony Vaio PCG-7A2L laptop.
  1. Lay the closed laptop on its screen so the bottom is facing towards you.
    • Lay the closed laptop on its screen so the bottom is facing towards you.
  2. Push both latches towards the center of the battery.
    • Push both latches towards the center of the battery.
  3. Revome the battery by pushing it away from the laptop. Set the battery away from the laptop.
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
  4. Batteries pour ordinateurs portables
    Une réparation facile pour un gain en puissance max.
    Acheter maintenant
    Acheter maintenant
  5. With the bottom of the laptop facing up, locate the RAM cover. The RAM is covered by the panel with four columns of vents.
    • With the bottom of the laptop facing up, locate the RAM cover.
    • The RAM is covered by the panel with four columns of vents.
    • Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
  6. Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters) Once the panel is out of its locked position, it can be lifted out without any resistance. Once the panel is out of its locked position, it can be lifted out without any resistance.
    • Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters)
    • Once the panel is out of its locked position, it can be lifted out without any resistance.
  7. To remove the RAM, use sharp end of a spudger to push the two silver tabs (see picture) away from the green RAM chip. When both silver tabs are moved to the side, one edge of the RAM chip will pop up from its original position. Use your fingers to grab the raised edge of the RAM and pull the chip away from its connection to the laptop.
    • To remove the RAM, use sharp end of a spudger to push the two silver tabs (see picture) away from the green RAM chip.
    • When both silver tabs are moved to the side, one edge of the RAM chip will pop up from its original position.
    • Use your fingers to grab the raised edge of the RAM and pull the chip away from its connection to the laptop.
  8. To install the new RAM, grip the new chip exactly the same way as you gripped the old chip when you removed it.
    • To install the new RAM, grip the new chip exactly the same way as you gripped the old chip when you removed it.
    • Insert the gold leads of the RAM into the connection at the same angle the original chip was raised at after the tabs were released.
    • There is a raised tab on the connection that mates with a slit in the RAM to ensure you do not put the chip in upside down.
  9. To finish the RAM installation, use your finger to push down on the center of the RAM until it clips into the silver tabs and locks into place.
Ligne d'arrivée
2 autre(s) ont terminé cette réparation.
Michael Maravick
Membre depuis le 15/04/2010
63 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 24-32, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 24-32, Regan Spring 2010
CPSU-REGAN-S10S24G32
4 membres
8 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 9,872
