With this step by step guide you will learn how to replace a laptop battery for the Sony Vaio PCG-981L.
Before starting, be sure the device is turned off and disconnected from any power cords.
Place the device on a flat surface.
Flip the laptop over so that the bottom is facing up but the battery cover is still facing you.
In this new orientation, the battery cover is located on the left side.
Once lifted, the battery cover should flip open.
Now, carefully remove the battery from the device.
Now, the battery should be completely removed from the device.
Be sure to dispose of the old battery properly and then you are finished.
Intégrer ce tutoriel
Choisissez une taille et copiez le code ci-dessous pour intégrer ce tutoriel sous la forme d'un petit widget sur votre site / forum.
Aperçu
