Aller au contenu principal
Introduction
This guide will help you replace the clock battery in your Sony Vaio PCG-981L computer. Before starting, check to make sure your computer model matches the one in this guide as there may be differences in design. Next, make sure all of your files are saved and backed up, shut down your computer properly, and remove all cords.
Pièces
Aucune pièce spécifiée.
  1. Sony Vaio PCG-981L Clock battery Replacement, Clock Battery: étape 1, image 1 de 1
    • Place the computer on a flat surface.
  2. Sony Vaio PCG-981L Clock battery Replacement: étape 2, image 1 de 2 Sony Vaio PCG-981L Clock battery Replacement: étape 2, image 2 de 2
    • Flip your computer upside down.
    • Using your Phillips #1 Screwdriver, remove the screw securing the cover turning your screwdriver counterclockwise.
  3. Sony Vaio PCG-981L Clock battery Replacement: étape 3, image 1 de 1
    • Remove the capsule cover to reveal the computer chip.
  4. Sony Vaio PCG-981L Clock battery Replacement: étape 4, image 1 de 1
    • After removing the cover, identify the two screws holding the computer chip in place.
    • Using your Phillips #1 Screwdriver, remove the two screws that secure the computer chip by turning your screwdriver counterclockwise.
  5. Sony Vaio PCG-981L Clock battery Replacement: étape 5, image 1 de 1
    • Carefully remove the computer chip and set it aside.
  6. Sony Vaio PCG-981L Clock battery Replacement: étape 6, image 1 de 1
    • Using your thumb or index finger, locate the clock battery on the upper part of the capsule.
    • Apply pressure to the clock battery until it pops out and remove it from your computer.
  7. Sony Vaio PCG-981L Clock battery Replacement: étape 7, image 1 de 1
    • Push your new clock battery into place using your thumb or index finger at the same place where you removed the old clock battery.
  8. Sony Vaio PCG-981L Clock battery Replacement: étape 8, image 1 de 1
    • Carefully replace the computer chip and secure the two screws using your Phillips #1 Screwdriver by turning the screwdriver clockwise.
  9. Sony Vaio PCG-981L Clock battery Replacement: étape 9, image 1 de 1
    • Secure the capsule cover with the screw the same way.
  10. Sony Vaio PCG-981L Clock battery Replacement: étape 10, image 1 de 1
    • Flip your computer right side up and turn it on to make sure everything is functioning properly.
If your computer does not function properly after you have completed this guide, please review the guide to see if you missed a step. If not, contact your computer manufacturer for assistance.
Gabriel Camorlinga
Membre depuis le 20/04/2010
43 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 18-68, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 18-68, Johann Spring 2010
CPSU-JOHANN-S10S18G68
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 14
Total : 4,378
