Aller au contenu principal
Sony Vaio PCG-F360 Floppy Drive Replacement
  1. Sony Vaio PCG-F360 Floppy Drive Replacement, Battery: étape 1, image 1 de 1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony Vaio PCG-F360 Floppy Drive Replacement: étape 2, image 1 de 1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony Vaio PCG-F360 Floppy Drive Replacement: étape 3, image 1 de 1
    • Use the indentations to pull the old battery out.
  4. Sony Vaio PCG-F360 Floppy Drive Replacement: étape 4, image 1 de 1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony Vaio PCG-F360 Floppy Drive Replacement, Floppy Drive: étape 5, image 1 de 2 Sony Vaio PCG-F360 Floppy Drive Replacement, Floppy Drive: étape 5, image 2 de 2
    • With one hand slide and hold the tab shown.
    • With your other hand, pull the floppy drive out of the floppy drive bay.
    • To replace the floppy drive, simply slide the drive into the slot until it clicks.
ahintz
Membre depuis le 04/21/10
28 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 16-3, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 16-3, Maness Spring 2010
CPSU-MANESS-S10S16G3
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 2,755
