Aller au contenu principal
Sony Vaio PCG-F360 Keyboard Replacement
Ce dont vous avez besoin
  1. Sony Vaio PCG-F360 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony Vaio PCG-F360 Keyboard Replacement: étape 2, image 1 de 1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony Vaio PCG-F360 Keyboard Replacement: étape 3, image 1 de 1
    • Use the indentations to pull the old battery out.
  4. Sony Vaio PCG-F360 Keyboard Replacement: étape 4, image 1 de 1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony Vaio PCG-F360 Keyboard Replacement, Keyboard: étape 5, image 1 de 3 Sony Vaio PCG-F360 Keyboard Replacement, Keyboard: étape 5, image 2 de 3 Sony Vaio PCG-F360 Keyboard Replacement, Keyboard: étape 5, image 3 de 3
    • There are two screws on the left hand side of the laptop near the IR (Infared remote) receiver (see image). Remove them using a Phillips #00 Screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. Sony Vaio PCG-F360 Keyboard Replacement: étape 6, image 1 de 3 Sony Vaio PCG-F360 Keyboard Replacement: étape 6, image 2 de 3 Sony Vaio PCG-F360 Keyboard Replacement: étape 6, image 3 de 3
    • On the inside of the speaker panel, using a spudger, push the beige tab in the direction of the ribbon. It should only move a small amount.
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
  7. Sony Vaio PCG-F360 Keyboard Replacement: étape 7, image 1 de 2 Sony Vaio PCG-F360 Keyboard Replacement: étape 7, image 2 de 2
    • Remove the metal screw that will be located at the red circle.
    • Pull on the green strip, and the keyboard should come free easily.
ahintz
Membre depuis le 04/21/10
28 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 16-3, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 16-3, Maness Spring 2010
CPSU-MANESS-S10S16G3
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 23
Total : 1,361
