Introduction
Replacing the CD/DVD drive involves first removing the keyboard, then a screw will free it from the frame. Then, simply unplug the ribbon cable and pull it out.
CAUTION: Static electricity in your body can ruin you computer. Use an anti-static wristband.
Pièces
Aucune pièce spécifiée.
The battery is located on the left side of the laptop as shown by the red circle.
Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
After removing the keyboard, unscrew (using Phillips #00) the circled screw securing the CD/DVD drive.
