Aller au contenu principal
Introduction
Upgrading or replacing the RAM modules in the laptop.
CAUTION: Static electricity from your body can damage RAM any component in your computer. Either use an anti-static wristband, or ground yourself periodically by touching a large piece of metal.
Pièces
Aucune pièce spécifiée.
  1. The battery is located on the left side of the laptop as shown by the red circle.
    • The battery is located on the left side of the laptop as shown by the red circle.
  2. Pull the plastic cover down (indicated by the arrow) and then swing it upwards to reveal the battery compartment.
    • Pull the plastic cover down (indicated by the arrow) and then swing it upwards to reveal the battery compartment.
    • The battery can now be removed by pulling it.
  3. Fix Kits pour iPhone X
    Finie la garantie ? Pas de soucis, nous avons de quoi réparer.
    Acheter maintenant
    Acheter maintenant
  4. Remove the screw holding the RAM cover down.
    • Remove the screw holding the RAM cover down.
  5. Use a flat object like a flat head screwdriver to lift the covering, revealing the RAM modules inside the computer.
    • Use a flat object like a flat head screwdriver to lift the covering, revealing the RAM modules inside the computer.
  6. To remove the RAM currently inside the computer, gently pull out the white tabs on each side of the RAM module.
    • To remove the RAM currently inside the computer, gently pull out the white tabs on each side of the RAM module.
    • The RAM will pop up at an angle where it can be pulled out without damaging the socket.
    • Remove the RAM module by pulling at the same angle the RAM is at.
  7. To insert the new RAM module, match the notch in the middle of the gold edge of the RAM to the notch in the laptop.
    • To insert the new RAM module, match the notch in the middle of the gold edge of the RAM to the notch in the laptop.
    • Insert the RAM at the same angle the other module came out at and make sure the end of the ram is actually in the slot. Gently push down on the RAM until it clicks in.
Ligne d'arrivée
Therin Irwin
Membre depuis le 19/04/2010
7 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 29-77, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 29-77, Johann Spring 2010
CPSU-JOHANN-S10S29G77
5 membres
6 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 2,134
