Aller au contenu principal
Sony Vaio SVF15N17CXB Hard Drive Replacement
Ce dont vous avez besoin
  1. Sony Vaio SVF15N17CXB Hard Drive Replacement, Back Panel: étape 1, image 1 de 1
    • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • 6 mm screws marked in red, 4 mm marked in orange
  2. Sony Vaio SVF15N17CXB Hard Drive Replacement: étape 2, image 1 de 2 Sony Vaio SVF15N17CXB Hard Drive Replacement: étape 2, image 2 de 2
    • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
    • In reassembly, slide the optical drive back in after reapplying cover.
  3. Sony Vaio SVF15N17CXB Hard Drive Replacement: étape 3, image 1 de 1
    • Run the opening tool along the bottom cover seam.
  4. Sony Vaio SVF15N17CXB Hard Drive Replacement: étape 4, image 1 de 1
    • Lift the clip marked in red in order to release the back cover.
    • Lift the back cover.
  5. Sony Vaio SVF15N17CXB Hard Drive Replacement, Hard Drive: étape 5, image 1 de 1
    • Unscrew the three 4mm screws with the Phillips #0 screwdriver located on the outer edge of the hard drive.
  6. Sony Vaio SVF15N17CXB Hard Drive Replacement: étape 6, image 1 de 1
    • Lift hard drive up from it groundings.
    • Slide hard drive to the left in order to remove it.
Quinn Walter
Membre depuis le 10/04/18
311 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 9
Total : 1,126
