Ce dont vous avez besoin
Begin by opening the HDMI/USB port cover on the left edge.
Remove the three #000 headed, 3 mm long screws located underneath the port cover.
Disconnect the battery from the motherboard by pulling out the cable below the fan.
Gently pull the motherboard out by pulling from the right side of the board and flip it so that the motherboard now sits where the battery was and the underside is now visible.
Remove the speaker connector located next to the SSD slot.
You may now remove the motherboard from the device.
Once the motherboard is out of the device, removal of the camera module is simple.
Pull out the ribbon connector from the motherboard next to the module, then remove the camera module.
2 autres ont terminé cette réparation.
