Aller au contenu principal
Sony Vaio VGN-FS640 Fan Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Sony Vaio VGN-FS640 Fan Replacement, Backplate: étape 1, image 1 de 1
    • Turn off the laptop and disconnect any charging cables.
    • Flip the laptop over so that the Service Tag is shown at the top left corner.
  2. Sony Vaio VGN-FS640 Fan Replacement: étape 2, image 1 de 1
    • Remove the highlighted screws from the back of the laptop with a Phillips #0 Screwdriver.
  3. Sony Vaio VGN-FS640 Fan Replacement: étape 3, image 1 de 1
    • Remove the highlighted screws from the panels in the bottom right-hand corner of the laptop using the Phillips #0 Screwdriver.
  4. Sony Vaio VGN-FS640 Fan Replacement: étape 4, image 1 de 1
    • Remove the two panels in the bottom right-hand corner by sliding in the direction of the arrows imprinted on the panels.
  5. Sony Vaio VGN-FS640 Fan Replacement: étape 5, image 1 de 1
    • Remove the highlighted screws underneath the removed panels using the Phillips #0 Screwdriver.
  6. Sony Vaio VGN-FS640 Fan Replacement: étape 6, image 1 de 1
    • Carefully remove the hard drive from the panel in the bottom right-hand corner of the laptop.
  7. Sony Vaio VGN-FS640 Fan Replacement: étape 7, image 1 de 1
    • Locate the battery, located on the top side of the laptop to the right of the Service Tag .
    • Remove the battery by pressing inwards on the tabs on either side of the battery.
  8. Sony Vaio VGN-FS640 Fan Replacement: étape 8, image 1 de 1
    • Remove cover in the top left side of the laptop next to the battery by pulling it outwards.
  9. Sony Vaio VGN-FS640 Fan Replacement: étape 9, image 1 de 1
    • Remove the backplate of the laptop by pulling it away from the laptop.
  10. Sony Vaio VGN-FS640 Fan Replacement, Fan: étape 10, image 1 de 3 Sony Vaio VGN-FS640 Fan Replacement, Fan: étape 10, image 2 de 3 Sony Vaio VGN-FS640 Fan Replacement, Fan: étape 10, image 3 de 3
    • Gently remove the connector for the wire running over the fan by lifting the tab on top up with your fingernail and sliding it out.
  11. Sony Vaio VGN-FS640 Fan Replacement: étape 11, image 1 de 2 Sony Vaio VGN-FS640 Fan Replacement: étape 11, image 2 de 2
    • Remove the four screws securing the fan.
  12. Sony Vaio VGN-FS640 Fan Replacement: étape 12, image 1 de 2 Sony Vaio VGN-FS640 Fan Replacement: étape 12, image 2 de 2
    • Gently lift out the fan.
    • Do not forcefully pull the fan away. This may damage the circuit board.
  13. Sony Vaio VGN-FS640 Fan Replacement: étape 13, image 1 de 2 Sony Vaio VGN-FS640 Fan Replacement: étape 13, image 2 de 2
    • Gently disconnect the remaining wire connecting the fan to the circuit board.
    • Remove the fan from the laptop.
Geoffrey
Membre depuis le 03/28/14
252 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-6, Vijaybhaskar Spring 2014 Membre de l'équipe UMass Dartmouth, Team 2-6, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S2G6
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 7
Total : 538
