Aller au contenu principal
Sony Vaio VGN-FS640 Hard Drive Replacement
Ce dont vous avez besoin
  1. Sony Vaio VGN-FS640 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Lay the closed laptop on its screen so the bottom is facing towards you.
  2. Sony Vaio VGN-FS640 Hard Drive Replacement: étape 2, image 1 de 1
    • Push both latches towards the center of the battery.
  3. Sony Vaio VGN-FS640 Hard Drive Replacement: étape 3, image 1 de 2 Sony Vaio VGN-FS640 Hard Drive Replacement: étape 3, image 2 de 2
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
  4. Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: étape 4, image 1 de 3 Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: étape 4, image 2 de 3 Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: étape 4, image 3 de 3
    • Locate and remove the screw (Length: 7.7mm) for the hard drive cover.
    • Slide the cover until it is free from the laptop case.
    • Lift the cover to remove.
  5. Sony Vaio VGN-FS640 Hard Drive Replacement: étape 5, image 1 de 3 Sony Vaio VGN-FS640 Hard Drive Replacement: étape 5, image 2 de 3 Sony Vaio VGN-FS640 Hard Drive Replacement: étape 5, image 3 de 3
    • Locate and remove the four screws (Length: 7.7mm) holding the Hard Drive tray in place.
    • Using the tab on the tray, slide the Hard Drive away from the main body of the laptop.
    • The Hard Drive should now be disconnected.
    • Lift the drive out with the tab on the tray.
2 autres ont terminé cette réparation.
Matt McCarty
Membre depuis le 04/15/10
220 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 24-32, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 24-32, Regan Spring 2010
CPSU-REGAN-S10S24G32
4 membres
16 tutoriels rédigés
Un commentaire
cant sign to recover my external hard drive
manivanan88 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 17
Total : 10,581
