Aller au contenu principal
Sony Vaio VGN-FS640 RAM Cover Replacement
Ce dont vous avez besoin
  1. Sony Vaio VGN-FS640 RAM Cover Replacement, Battery: étape 1, image 1 de 1
    • Lay the closed laptop on its screen so the bottom is facing towards you.
  2. Sony Vaio VGN-FS640 RAM Cover Replacement: étape 2, image 1 de 1
    • Push both latches towards the center of the battery.
  3. Sony Vaio VGN-FS640 RAM Cover Replacement: étape 3, image 1 de 2 Sony Vaio VGN-FS640 RAM Cover Replacement: étape 3, image 2 de 2
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
  4. Sony Vaio VGN-FS640 RAM Cover Replacement, RAM Cover: étape 4, image 1 de 2 Sony Vaio VGN-FS640 RAM Cover Replacement, RAM Cover: étape 4, image 2 de 2
    • With the bottom of the laptop facing up, locate the RAM cover.
    • The RAM is covered by the panel with four columns of vents.
    • Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
  5. Sony Vaio VGN-FS640 RAM Cover Replacement: étape 5, image 1 de 3 Sony Vaio VGN-FS640 RAM Cover Replacement: étape 5, image 2 de 3 Sony Vaio VGN-FS640 RAM Cover Replacement: étape 5, image 3 de 3
    • Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters)
    • Once the panel is out of its locked position, it can be lifted out without any resistance.
Brian Marchini
Membre depuis le 04/15/10
293 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 24-32, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 24-32, Regan Spring 2010
CPSU-REGAN-S10S24G32
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 4,801
