Aller au contenu principal
Sony Vaio VGN-S260 Ethernet Ports Replacement
Ce dont vous avez besoin
  1. Sony Vaio VGN-S260 Ethernet Ports Replacement, Battery: étape 1, image 1 de 3 Sony Vaio VGN-S260 Ethernet Ports Replacement, Battery: étape 1, image 2 de 3 Sony Vaio VGN-S260 Ethernet Ports Replacement, Battery: étape 1, image 3 de 3
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 2, image 1 de 2 Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 2, image 2 de 2
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 Ethernet Ports Replacement, Keyboard: étape 3, image 1 de 2 Sony Vaio VGN-S260 Ethernet Ports Replacement, Keyboard: étape 3, image 2 de 2
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 4, image 1 de 1
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 5, image 1 de 2 Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 5, image 2 de 2
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 6, image 1 de 2 Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 6, image 2 de 2
    • Lift up lever underneath the ribbon to detach the keyboard.
  7. Sony Vaio VGN-S260 Ethernet Ports Replacement, Upper Casing: étape 7, image 1 de 1
    • Remove memory/wireless compartment cover.
  8. Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 8, image 1 de 3 Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 8, image 2 de 3 Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 8, image 3 de 3
    • Flip so the Vaio Logo is face down.
    • Locate and remove a total of 8 screws on the bottom.
  9. Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 9, image 1 de 1
    • Find and remove 5 screws (they all have arrows next to them) from cover.
  10. Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 10, image 1 de 3 Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 10, image 2 de 3 Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 10, image 3 de 3
    • Flip the laptop over so the Vaio logo is face up.
    • Use the spudger to pop up the upper casing.
    • Do not lift too much as the upper casing is attached to wires underneath.
    • Remove the wires that are attaching the upper casing to the motherboard.
  11. Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 11, image 1 de 1
    • Remove the upper casing.
  12. Sony Vaio VGN-S260 Ethernet Ports Replacement, Optical Drive: étape 12, image 1 de 1
    • Remove the screw holding the optical drive casing to the logic board.
  13. Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 13, image 1 de 1
    • Locate ribbon connecting optical drive case to logic board.
    • Pop off the ribbon.
    • Remove the metal PC-Card cage.
  14. Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 14, image 1 de 1
    • Remove the four screws holding the optical drive to the logic board.
  15. Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 15, image 1 de 2 Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 15, image 2 de 2
    • Locate brown locking tab above optical drive.
    • Lift up on brown locking tab until ribbon is loose.
    • Gently slide out and remove the optical drive from the computer.
  16. Sony Vaio VGN-S260 Ethernet Ports Replacement, Ethernet Ports: étape 16, image 1 de 2 Sony Vaio VGN-S260 Ethernet Ports Replacement, Ethernet Ports: étape 16, image 2 de 2
    • Remove the blue ribbon from the Ethernet Circuit Board.
  17. Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 17, image 1 de 1
    • Remove the screws near the Ethernet Port circuit board.
  18. Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 18, image 1 de 1
    • Remove the screws for the second ethernet circuit board.
  19. Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 19, image 1 de 2 Sony Vaio VGN-S260 Ethernet Ports Replacement: étape 19, image 2 de 2
    • Remove the ethernet ports.
Jeffrey Bryan
Membre depuis le 04/20/10
570 Réputation
11 tutoriels rédigés
Équipe
Cal Poly, Team 16-4, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 16-4, Maness Spring 2010
CPSU-MANESS-S10S16G4
4 membres
30 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 3,540
