Aller au contenu principal
Introduction
This guide will show you how to carefully remove the keyboard from your Sony Vaio.
  1. Start with the laptop face up on a flat surface.
    • Start with the laptop face up on a flat surface.
  2. Open the laptop with the keyboard facing you.
    • Open the laptop with the keyboard facing you.
  3. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  4. Use a plastic opening tool to pry up the keyboard. Start at the end closest to the screen. Be careful around the edges; work your way around the keyboard until all of it is detached.
    • Use a plastic opening tool to pry up the keyboard. Start at the end closest to the screen.
    • Be careful around the edges; work your way around the keyboard until all of it is detached.
    • There will be a ribbon cable attached to the bottom of the keyboard. Be sure not to rip the cable when lifting the keyboard from the laptop frame.
  5. Carefully detach the ribbon from the  base of the computer with your hands. Remove the keyboard.
    • Carefully detach the ribbon from the base of the computer with your hands.
    • Remove the keyboard.
Giselle Dougan
Membre depuis le 31/01/2018
742 Réputation
5 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 5
Total : 129
