Aller au contenu principal
Sony Vaio VPCW21FX Hard Drive Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Sony Vaio VPCW21FX Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Make sure your device is powered off and unplugged to avoid electric shock.
    • Place your device upside down with the bottom panel facing upwards.
    • Orient the device so the battery is away from you as shown
  2. Sony Vaio VPCW21FX Hard Drive Replacement: étape 2, image 1 de 2 Sony Vaio VPCW21FX Hard Drive Replacement: étape 2, image 2 de 2
    • Unlock the battery by sliding the lock switch to the right.
    • Locate the release latch. Slide the latch to the left to remove the battery from your laptop.
    • Be sure to lift up on the battery while you slide the latch to the left.
  3. Sony Vaio VPCW21FX Hard Drive Replacement: étape 3, image 1 de 2 Sony Vaio VPCW21FX Hard Drive Replacement: étape 3, image 2 de 2
    • Remove the battery from your laptop.
  4. Sony Vaio VPCW21FX Hard Drive Replacement, Hard Drive: étape 4, image 1 de 3 Sony Vaio VPCW21FX Hard Drive Replacement, Hard Drive: étape 4, image 2 de 3 Sony Vaio VPCW21FX Hard Drive Replacement, Hard Drive: étape 4, image 3 de 3
    • Remove the two 4.8mm screws that are holding the bottom right panel cover.
    • Remove the Panel cover by lifting it up.
  5. Sony Vaio VPCW21FX Hard Drive Replacement: étape 5, image 1 de 2 Sony Vaio VPCW21FX Hard Drive Replacement: étape 5, image 2 de 2
    • Remove the two 4.8mm screws that are holding the hard drive down.
  6. Sony Vaio VPCW21FX Hard Drive Replacement: étape 6, image 1 de 3 Sony Vaio VPCW21FX Hard Drive Replacement: étape 6, image 2 de 3 Sony Vaio VPCW21FX Hard Drive Replacement: étape 6, image 3 de 3
    • Grab the black tab that is attached to the hard drive.
    • Slide hard drive to the left to release it from the computer
    • Pull drive up from there and it will come out.
Nicholas Corcoran
Membre depuis le 03/08/17
401 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G5, Isaacson Spring 2017 Membre de l'équipe UMass Dartmouth, Team S2-G5, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G5
2 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 521
