Introduction
In this guide, you will learn how to remove and replace the Hard Drive from your laptop. If you have this exact laptop, follow the below steps. If you have another laptop, that is still okay, these steps will give you a basic understanding on how to remove the Hard Drive and you can adapt them to your own computer.
Ce dont vous avez besoin
Place your device upside down with the bottom panel facing upwards.
Orient the device so the battery is away from you as shown
Remove the two 4.8mm screws that are holding the bottom right panel cover.
Remove the Panel cover by lifting it up.
