Aller au contenu principal
Sony Vaio VPCW21FX Keyboard Replacement
Ce dont vous avez besoin
  1. Sony Vaio VPCW21FX Keyboard Replacement, Battery: étape 1, image 1 de 3 Sony Vaio VPCW21FX Keyboard Replacement, Battery: étape 1, image 2 de 3 Sony Vaio VPCW21FX Keyboard Replacement, Battery: étape 1, image 3 de 3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio VPCW21FX Keyboard Replacement: étape 2, image 1 de 3 Sony Vaio VPCW21FX Keyboard Replacement: étape 2, image 2 de 3 Sony Vaio VPCW21FX Keyboard Replacement: étape 2, image 3 de 3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: étape 3, image 1 de 3 Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: étape 3, image 2 de 3 Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: étape 3, image 3 de 3
    • Open the Lid of the laptop
    • Then using they pry tool to carefully remove the plastic cover around the keyboard
    • It helps to pry from one of the larger keys as they have more room to fit the tool in
  4. Sony Vaio VPCW21FX Keyboard Replacement: étape 4, image 1 de 3 Sony Vaio VPCW21FX Keyboard Replacement: étape 4, image 2 de 3 Sony Vaio VPCW21FX Keyboard Replacement: étape 4, image 3 de 3
    • Close the lid and flip the laptop over
    • Loosen but do not remove the screw on center panel and remove Panel.
  5. Sony Vaio VPCW21FX Keyboard Replacement: étape 5, image 1 de 2 Sony Vaio VPCW21FX Keyboard Replacement: étape 5, image 2 de 2
    • Remove the three 5mm screws that are holding in the keyboard.
  6. Sony Vaio VPCW21FX Keyboard Replacement: étape 6, image 1 de 3 Sony Vaio VPCW21FX Keyboard Replacement: étape 6, image 2 de 3 Sony Vaio VPCW21FX Keyboard Replacement: étape 6, image 3 de 3
    • Flip laptop over again and open the lid
    • Lift up the keyboard from the top and lean it toward you to expose the connector on the back
    • Grab the wire from the keyboard close to the connector and pull carefully to the left to disconnect it from the laptop.
Nicholas Corcoran
Membre depuis le 03/08/17
401 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G5, Isaacson Spring 2017 Membre de l'équipe UMass Dartmouth, Team S2-G5, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G5
2 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 5
30 derniers jours : 22
Total : 2,181
