Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
In this guide, you will learn how to remove and replace the RAM Memory Chips from your laptop. If you have this exact laptop, follow the below steps. If you have another laptop, that is still okay, these steps will give you a basic understanding on how to remove the RAM Memory Chips and you can adapt them to your own computer.
Pièces
Aucune pièce spécifiée.
  1. Make sure your device is powered off and unplugged to avoid electric shock.
    • Make sure your device is powered off and unplugged to avoid electric shock.
    • Place your device upside down with the bottom panel facing upwards.
    • Orient the device so the battery is away from you as shown
  2. Unlock the battery by sliding the lock switch to the right. Locate the release latch. Slide the latch to the left to remove the battery from your laptop.
    • Unlock the battery by sliding the lock switch to the right.
    • Locate the release latch. Slide the latch to the left to remove the battery from your laptop.
    • Be sure to lift up on the battery while you slide the latch to the left.
  3. Remove the battery from your laptop. Remove the battery from your laptop.
    • Remove the battery from your laptop.
  4. Loosen but do not remove the screw over RAM cover panel. With the screw loosened but not removed, lift up and remove the panel. With the screw loosened but not removed, lift up and remove the panel.
    • Loosen but do not remove the screw over RAM cover panel.
    • With the screw loosened but not removed, lift up and remove the panel.
  5. Locate the mounting bracket holding the RAM Chips in the computer. Pull silver tabs away from the chip. The chip will pop up, this is normal.
    • Locate the mounting bracket holding the RAM Chips in the computer.
    • Pull silver tabs away from the chip.
    • The chip will pop up, this is normal.
    • Don't touch gold pins on RAM chip.
  6. Slide RAM chip out by holding the sides of the chip and pull away from the computer. Repeat previous steps for second RAM chip.
    • Slide RAM chip out by holding the sides of the chip and pull away from the computer.
    • Repeat previous steps for second RAM chip.
Nicholas Corcoran
Membre depuis le 08/03/2017
401 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G5, Isaacson Spring 2017 Membre de l'équipe UMass Dartmouth, Team S2-G5, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G5
2 membres
4 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 39
Total : 393
