Aller au contenu principal
Sony Walkman NWZ-E438 Battery Replacement
Ce dont vous avez besoin
  1. Sony Walkman NWZ-E438 Battery Replacement, Disassembling Sony Walkman NWZ-E438: étape 1, image 1 de 1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Battery Replacement: étape 2, image 1 de 1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Battery Replacement, Battery: étape 3, image 1 de 1
    • Peel back the black tape from the device to the battery from the side of the device.
  4. Sony Walkman NWZ-E438 Battery Replacement: étape 4, image 1 de 1
    • Using a small, plastic prying tool slowly lift the battery around all edges.
    • Careful of wires connecting the battery to the device.
  5. Sony Walkman NWZ-E438 Battery Replacement: étape 5, image 1 de 1
    • Remove the yellow film covering the circuit board with pointed precision tweezers.
  6. Sony Walkman NWZ-E438 Battery Replacement: étape 6, image 1 de 2 Sony Walkman NWZ-E438 Battery Replacement: étape 6, image 2 de 2
    • Using tweezers, unplug the gold band connecting the device and circuit board.
  7. Sony Walkman NWZ-E438 Battery Replacement: étape 7, image 1 de 2 Sony Walkman NWZ-E438 Battery Replacement: étape 7, image 2 de 2
    • Using pointed precision tweezers, unplug the wires connecting the battery and chip from the chip.
  8. Sony Walkman NWZ-E438 Battery Replacement: étape 8, image 1 de 1
    • Remove battery.
Cheryl Zinn
Membre depuis le 10/08/15
525 Réputation
5 tutoriels rédigés
Équipe
Un commentaire
Do you have a link to purchase a replacement battery? Thanks!
jacob goff - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 15
30 derniers jours : 46
Total : 6,441
