Aller au contenu principal
Sony Walkman NWZ-E438 USB Port Replacement
Ce dont vous avez besoin
  1. Sony Walkman NWZ-E438 USB Port Replacement, Disassembling Sony Walkman NWZ-E438: étape 1, image 1 de 1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 USB Port Replacement: étape 2, image 1 de 1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 USB Port Replacement, Circuit Board: étape 3, image 1 de 3 Sony Walkman NWZ-E438 USB Port Replacement, Circuit Board: étape 3, image 2 de 3 Sony Walkman NWZ-E438 USB Port Replacement, Circuit Board: étape 3, image 3 de 3
    • First, you must remove the black tape on the circuit board.
    • Next, pull up on the red and gold band until it detaches from the chip.
  4. Sony Walkman NWZ-E438 USB Port Replacement: étape 4, image 1 de 2 Sony Walkman NWZ-E438 USB Port Replacement: étape 4, image 2 de 2
    • Using a small plastic prying tool, slip the end under the device circuit board and slowly lift it.
    • Once the circuit board is lifted, carefully remove the chip with tweezers.
    • The circuit board will still be connected to the device by a wire.
  5. Sony Walkman NWZ-E438 USB Port Replacement: étape 5, image 1 de 1
    • Using a soldering iron, carefully heat the metal connecting the wires from the device to the circuit board.
    • You will need the soldering iron to reattach those wires once you've replaced the circuit board.
  6. Sony Walkman NWZ-E438 USB Port Replacement: étape 6, image 1 de 1
    • Carefully remove the circuit board from the device.
  7. Sony Walkman NWZ-E438 USB Port Replacement, USB Port: étape 7, image 1 de 1
    • Using fine point tweezers, push them between the chip and USB port.
  8. Sony Walkman NWZ-E438 USB Port Replacement: étape 8, image 1 de 1
    • Slowly pry the USB port off of the chip.
    • You will need to solder the new USB onto the circuit board.
  9. Sony Walkman NWZ-E438 USB Port Replacement: étape 9, image 1 de 1
    • Remove USB port.
Cheryl Zinn
Membre depuis le 10/08/15
525 Réputation
5 tutoriels rédigés
Équipe
Un commentaire
Wher buy new port????pavel87cz@gmail.com
Pavel Drobny - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 585
