Aller au contenu principal
Sony Walkman NWZ-S764 Battery Replacement
Ce dont vous avez besoin
  1. Sony Walkman NWZ-S764 Battery Replacement, Removing the back cover: étape 1, image 1 de 3 Sony Walkman NWZ-S764 Battery Replacement, Removing the back cover: étape 1, image 2 de 3 Sony Walkman NWZ-S764 Battery Replacement, Removing the back cover: étape 1, image 3 de 3
    • Remove the two black 6.4mm Phillips screws from the back of the device.
  2. Sony Walkman NWZ-S764 Battery Replacement: étape 2, image 1 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 2, image 2 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 2, image 3 de 3
    • Using a plastic opening tool, work your way around the edges of the device, carefully prying off the front panel.
  3. Sony Walkman NWZ-S764 Battery Replacement: étape 3, image 1 de 2 Sony Walkman NWZ-S764 Battery Replacement: étape 3, image 2 de 2
    • Remove the two 2.8 mm phillips screws located on either side of the device near the top.
  4. Sony Walkman NWZ-S764 Battery Replacement: étape 4, image 1 de 2 Sony Walkman NWZ-S764 Battery Replacement: étape 4, image 2 de 2
    • Carefully pull the top piece away from the device.
  5. Sony Walkman NWZ-S764 Battery Replacement, Removing the Bluetooth module: étape 5, image 1 de 3 Sony Walkman NWZ-S764 Battery Replacement, Removing the Bluetooth module: étape 5, image 2 de 3 Sony Walkman NWZ-S764 Battery Replacement, Removing the Bluetooth module: étape 5, image 3 de 3
    • Use the flat end of the spudger to flip up the retaining flap for the bluetooth module.
    • Be sure to lift up on the retaining flap, and not the socket itself.
  6. Sony Walkman NWZ-S764 Battery Replacement: étape 6, image 1 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 6, image 2 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 6, image 3 de 3
    • Remove the two 1.8mm silver Phillips screws on the Bluetooth module.
    • Lift up on and remove the Bluetooth module.
    • The ribbon cable must first be removed in order to access the highlighted screw.
  7. Sony Walkman NWZ-S764 Battery Replacement, Audio Port: étape 7, image 1 de 3 Sony Walkman NWZ-S764 Battery Replacement, Audio Port: étape 7, image 2 de 3 Sony Walkman NWZ-S764 Battery Replacement, Audio Port: étape 7, image 3 de 3
    • Remove the two 2.8mm silver Phillips screws on the sides of the frame.
    • The two 2.8mm screws are on each side of the device.
    • Insert a plastic prying tool between the bottom of the case and the motherboard.
    • Pry up the assembly and lift it away from the case.
  8. Sony Walkman NWZ-S764 Battery Replacement: étape 8, image 1 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 8, image 2 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 8, image 3 de 3
    • Remove the yellow tape from the battery and volume control module.
    • Save tape for reassembly.
  9. Sony Walkman NWZ-S764 Battery Replacement: étape 9, image 1 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 9, image 2 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 9, image 3 de 3
    • Use a prying tool to pry under the volume control module.
    • This module is glued on, using too much force may damage or warp the module.
  10. Sony Walkman NWZ-S764 Battery Replacement: étape 10, image 1 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 10, image 2 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 10, image 3 de 3
    • Remove the tape from EMF shield and the LCD housing.
    • Lift up on the volume control ribbon.
  11. Sony Walkman NWZ-S764 Battery Replacement: étape 11, image 1 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 11, image 2 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 11, image 3 de 3
    • Insert a plastic opening tool under the battery and lift up to remove it.
    • The battery is glued on, too much force may damage the battery casing.
    • The battery is soldered to the motherboard, care should be taken to not place too much stress on the wires.
  12. Sony Walkman NWZ-S764 Battery Replacement: étape 12, image 1 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 12, image 2 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 12, image 3 de 3
    • Remove the black shielding tape from above the Hard Drive.
    • Peel the foam cover away from the hard drive.
    • Use a plastic opening tool to remove the EMF chip from the motherboard.
    • The hard drive is soldered onto the device. Be careful not to pull too hard on the hard drive.
  13. Sony Walkman NWZ-S764 Battery Replacement: étape 13, image 1 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 13, image 2 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 13, image 3 de 3
    • Remove the plastic bracket by pushing up with your thumb to expose the display connection.
  14. Sony Walkman NWZ-S764 Battery Replacement: étape 14, image 1 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 14, image 2 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 14, image 3 de 3
    • Use the flat end of a spudger to flip up the retaining flap on the audio jack module.
  15. Sony Walkman NWZ-S764 Battery Replacement: étape 15, image 1 de 2 Sony Walkman NWZ-S764 Battery Replacement: étape 15, image 2 de 2
    • Peel back the ribbon for the audio jack and remove the 1.8mm silver Phillips screw.
  16. Sony Walkman NWZ-S764 Battery Replacement: étape 16, image 1 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 16, image 2 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 16, image 3 de 3
    • Remove the mic casing by pushing up and in.
    • Remove the headphone jack and the bottom casing.
  17. Sony Walkman NWZ-S764 Battery Replacement, Motherboard: étape 17, image 1 de 2 Sony Walkman NWZ-S764 Battery Replacement, Motherboard: étape 17, image 2 de 2
    • Use the prying tool to remove the LCD ribbon wire.
  18. Sony Walkman NWZ-S764 Battery Replacement: étape 18, image 1 de 1
    • Lift up on the LCD ribbon and remove the two 1.8mm silver Phillips screws.
  19. Sony Walkman NWZ-S764 Battery Replacement: étape 19, image 1 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 19, image 2 de 3 Sony Walkman NWZ-S764 Battery Replacement: étape 19, image 3 de 3
    • Lift the motherboard away from the frame with your thumb to remove it from the device.
    • Pull the volume control module through the space in the frame.
    • If you are using the magnetic project pad or other magnetic surface to keep your screws, do not place the hard drive on or near the magnet.
  20. Sony Walkman NWZ-S764 Battery Replacement, Battery: étape 20, image 1 de 2 Sony Walkman NWZ-S764 Battery Replacement, Battery: étape 20, image 2 de 2
5 autres ont terminé cette réparation.
John Ferguson
Membre depuis le 01/21/15
657 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 4-2, Brown Winter 2015 Membre de l'équipe USF Tampa, Team 4-2, Brown Winter 2015
USFT-BROWN-W15S4G2
4 membres
6 tutoriels rédigés
3 commentaires
i have been trying for months now so your help would be great, i have a disabled wife, who does not sllepp at night she listens to audio books on the mp3 player, we have teken out the old battery but need to buy a replacemand asap please help, series and model no is enclosed below,
NWZ-S765 5563700
Regards
Dave
petriesuk - Réponse
Hi ich habe eine etwas leichtere Version bei der man sich die Arbeit und das Risiko ab schritt 12 sparen kann.
Ich habe alles wie hier bis zu schritt 11 gemacht.
-dann einfach die kabel vom akku auf der hälfte getrennt
-und dann den neuen akku an der stelle einfach wieder verlötet
-beide kabel mit 2 schrumpfschläuchen an den lötstellen isoliert
-und dann alles wieder zusammengebaut
Somit ist das ganze mit viel viel weniger Risiko verbunden das etwas von der Harware kaputt geht, da die ganzen Schritte ab Punkt 12 wegfallen.
hardstyle - Réponse
Buongiorno,
sembra semplice cambiare la batteria ma dove posso recuperarla?
La us323450 a7h sembra essere non più in commercio
F
Flavio - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 54
Total : 14,060
