Introduction
This repair guide will help you install a new USB cable for your car unit. It will ultimately enhance your experience while connecting the device to your car. This process requires you having a tool kit, specifically, the PH#0 screwdriver and a spudger. With that said, you should be good to go!
Ce dont vous avez besoin
Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
Remove the ten 3.5mm Phillips #0 screws from the back plate.
